1993 K1500 4x4 Blazer Trans ?'s
Old Dec 6, 2008 | 11:17 PM
chevyman09's Avatar
chevyman09 is an unknown quantity at this point
Default 1993 K1500 4x4 Blazer Trans ?'s
i have a 1993k1500 blazer it replaced the trans and it was leaking out of the rear out of the t-case so i replaced the seal and it still leaks from where idk but should i try to put teflon tape around the lines into the trans and the dipstick groument? also what year model trans fit into it i was told a 92-94 would be the only ones to fit?
Old Dec 7, 2008 | 07:58 AM
Default RE: 1993 K1500 4x4 Blazer Trans ?'s
Pull the fill plug from the back of the transfer case. If fluid pours out, then you have a failed input seal on the front of the transfer case. The transfer case needs to be removed to replace this seal.
JSmithTN
Feb 24, 2014 05:38 AM
Dechstang
Feb 10, 2014 09:06 PM
ctffa
Feb 1, 2014 02:15 PM
InsanePyro
Dec 12, 2013 01:08 AM
evlblkwpnz
Dec 18, 2009 08:26 AM
