1993 K1500 4x4 Blazer Trans ?'s
Old 12-06-2008, 11:17 PM
chevyman09's Avatar
chevyman09 is an unknown quantity at this point
Default 1993 K1500 4x4 Blazer Trans ?'s
i have a 1993k1500 blazer it replaced the trans and it was leaking out of the rear out of the t-case so i replaced the seal and it still leaks from where idk but should i try to put teflon tape around the lines into the trans and the dipstick groument? also what year model trans fit into it i was told a 92-94 would be the only ones to fit?
Old 12-07-2008, 07:58 AM
Default RE: 1993 K1500 4x4 Blazer Trans ?'s
Pull the fill plug from the back of the transfer case. If fluid pours out, then you have a failed input seal on the front of the transfer case. The transfer case needs to be removed to replace this seal.
JSmithTN
02-24-2014 05:38 AM
Dechstang
02-10-2014 09:06 PM
ctffa
02-01-2014 02:15 PM
InsanePyro
12-12-2013 01:08 AM
evlblkwpnz
12-18-2009 08:26 AM
Quick Reply: 1993 K1500 4x4 Blazer Trans ?'s
