is 50psi enough in my tires
Old Jan 27, 2007 | 06:31 PM
alamantia's Avatar
alamantia is an unknown quantity at this point
Default is 50psi enough in my tires
Just got 4 new BF goodrich 265/75/16 Trail tires for my truck, I only put 50 psi in for now should I go higher, in my car i only run 32-35, but I hear some trucks can take up to 80psi, naturally I would figure it would say in the door jamb butr i didnt see anything, these sidewalls say 65psi max, but I figure thats for towing which im not currently doing any of
Old Jan 27, 2007 | 06:51 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: is 50psi enough in my tires
my buddy runs the same size on his silverado... the BFG tire place reccomended between 50-55... i think he runs his closer to the 55 end... they ride pretty good.....
Old Jan 27, 2007 | 06:54 PM
KOYOTE's Avatar
KOYOTE is an unknown quantity at this point
It will say on tire sidewall for proper PSI.
Old Jan 28, 2007 | 01:56 AM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
ORIGINAL: KOYOTE
No, the side wall pressure is a MAXIMUM pressure recommendation for that specific tire......it has nothing to do with the proper PSI for this truck. I would assume that they are passenger car tires ( a "P" 265/75/16)? If so, just set them at the highest pressure you can to yield a good ride quality (I would suggest about 50-55 PSI like a_tack said) As for some trucks running 80 PSI yes some do and they are the "LT" tires which stands for light truck and are used on 3/4 ton and larger trucks typically.
Old Jan 28, 2007 | 01:19 PM
KOYOTE's Avatar
If passenger tires, I ran 40 to 45 PSI.
So your ride is not real hard.
bdemutis
Tires and Wheels
Apr 6, 2013 07:14 PM
old skool luvr
Jan 31, 2011 08:26 PM
Shalom
Jul 21, 2010 11:31 PM
99Jimmster
Tires and Wheels
Aug 20, 2009 08:51 PM
EuroGoldLS
Tires and Wheels
Mar 31, 2007 08:36 AM
