Will 31" tires be enough?
Old Mar 28, 2013 | 12:40 AM
bdemutis's Avatar
bdemutis is on a distinguished road
Default Will 31" tires be enough?
I went mudding yesterday. I have a 3" lift in the rear and I t-bar cranked the front. The front only sits 1" lower then the back. Well I have 250/75/15 good year wrangler radial on my 96 blazer right now. I got stuck yesterday in a rut. I was wondering if putting 31" tires or getting real 250/75/15 mud tires will help me not get stuck. I know I can't lift it any higher unless I do a solid axle swap witch is not in my budget right now.
Old Mar 29, 2013 | 09:44 AM
duxtoyz's Avatar
duxtoyz is on a distinguished road
31s would be great if u have the room, sounds like u should but some trimming may be needed. but 31s arent gonna help u not get stuck, its where u go and how u drive that helps u stay unstuck. 31s will just help a lil. and if u cant fit 31s than 'true' mud tires would help u, there again it depends where u go and how u drive.
Old Mar 29, 2013 | 12:18 PM
bdemutis's Avatar
It's swampy and its clay so it's like quick sand lol.
Old Mar 29, 2013 | 02:52 PM
duxtoyz's Avatar
then even with 44s on there being turned by a 500hp big block ul get stuck in the rite or wrong conditions. lol.
Old Mar 29, 2013 | 11:07 PM
bdemutis's Avatar
True I might just go with 30" mud tires even though I have a 3" shackle and t-bar cranked I don't feel like trimming if I rub.
Old Mar 30, 2013 | 09:35 AM
duxtoyz's Avatar
ul b fine, just stay out of quick sand......lol
Old Mar 30, 2013 | 10:25 AM
rexazz2's Avatar
I just put these on a couple weeks ago and they are pretty good in the deep snow
they are 30X9.5X15
Stock height and the snow has been deep enough to drag the dif
Old Apr 6, 2013 | 01:49 PM
trobbins's Avatar
why would you have to do a solid axle swap to lift it any higher? makes no since, since theres plenty of people on here with 5-9" of lift without a solid axle
Old Apr 6, 2013 | 07:14 PM
Diaita's Avatar
The main reason for solid axles is strength, not height. 33" or bigger tires don't mix well with the IFS parts, especially if you want to take it off-road.
old skool luvr
Jan 31, 2011 08:26 PM
Shalom
Jul 21, 2010 11:31 PM
midnightmekanik
Oct 8, 2009 08:32 PM
99Jimmster
Tires and Wheels
Aug 20, 2009 08:51 PM
alamantia
Jan 28, 2007 01:19 PM
