82 K5 blazer for sale/questions
Old Jan 20, 2010 | 08:23 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
Originally Posted by swartlkk
*Moving to Full Size Tech*
thanks i hit the submit thread then looked. better to check twice click once.
Old Jan 20, 2010 | 08:24 PM
Single digits.
Old Jan 20, 2010 | 08:27 PM
Banned
Single digits.
alright so about the same as my dads v10 gas.
5-8
Old Jan 20, 2010 | 09:51 PM
Banned
what else should i check on this to make sure im not getting a fixer upper. i know im gonna have the speedometer cables, and the fuel gauge, but being as old as it is what is most likely to fail.
Old Jan 21, 2010 | 11:11 AM
abig84's Avatar
the wheel bearings are easy in the sense that they usually come right out using that special socket of course.
heres a stupid write up i did for another site cause the question was asked once a week on how to do the bearings
http://www.midwestern4x4.com/forum/showthread.php?t=549
if he said its upper and lower speedo cables that means its going to have cruise control. and you can just buy a one piece if that cruise dont work
Old Jan 21, 2010 | 12:05 PM
How did you get that much crud in the hub?? LOL
What did you put back on there?
Old Jan 21, 2010 | 04:48 PM
Banned
i want to check and see what type of axle there are. i think their danas. how many bolts are they going to have on the back. also on these are they going to have a g80 like locker or a limited slip from the factory?
Old Jan 21, 2010 | 06:32 PM
Stock axles are going to be...
Front Axle: GM Corporate 10-bolt (8.5-in. 1.28 Axle Dia. 28 Spline)
Rear Axle: GM Corporate 10-bolt (8.5-in. 1.28 Axle Dia. 28 Spline)
And if it did come with the factory gov-loc (aka gov-bomb), hopefully it failed long ago and was replaced by a good differential. The early G80 diffs were horrible.
Old Jan 21, 2010 | 06:49 PM
Banned
alright i've seen some swaps of the open diffs to air lockers. they didn't look to bad to do a swap. i'll check on the diff when i go look at it. those axle you gave above are they "dana axles". i dont know for sure if the ones on it are stock or not. they'd be 28 year old axles (if they were stock)
Old Jan 21, 2010 | 07:12 PM
No, they are not Dana axles, they are GM Corporate 10-bolt axles.
