86' blazer k5 trouble
Old Oct 7, 2008 | 10:44 PM
kingoffrost's Avatar
kingoffrost is an unknown quantity at this point
Default 86' blazer k5 trouble
I've got a 86 blazer k5 that started will idle fine for about 5 mins and the stalls out... then won't start again I'm wondering what the possible reasons for this are.
I've heard it could be the fuel pump so where is that located on the blazer?
Old Oct 7, 2008 | 10:47 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: 86' blazer k5 trouble
what motor and it has a carburetor right not F.I.
Old Oct 7, 2008 | 10:56 PM
v8 with carburetor
*Combining Consecutive Posts*
350 v8
Old Oct 7, 2008 | 10:57 PM
350 v8
Old Oct 7, 2008 | 11:09 PM
2002XTREME's Avatar
Ok then i`m guessing that the choke on it needs to be tweaked a bit with the weather change. ( cold start issue is what it seems to me)..I have an 84 Elcamino that had a 305 in it and i hadto keep making all kinds of choke adjustments on it, until i put a 454 in it with a manual choke.. Problem solved..
Old Oct 7, 2008 | 11:29 PM
and how would I go about tweaking the choke?
Old Oct 8, 2008 | 07:46 AM
Default RE: 86 blazer k5 trouble
It sounds as though the choke may not be pulling off properly. This could be due to a faulty thermistor unit (what tells the electronic choke to open) or due to a gummed up choke linkage that is just stuck.
Another thing is that the idle feed jets are not properly adjusted or just dirty.
If it has never been done, I would recommend removing the carb and giving it a thorough cleaning. I did this on my 74 K5 and it was a remarkable difference in idle quality. I have another carb that I am going to rebuild and swap in.
Old Oct 9, 2008 | 02:42 AM
well if I try to put it in to gear after its started it dies right away
Old Oct 9, 2008 | 07:30 AM
Try cleaning the carb. See where that gets you.
fivemillerz
Jul 17, 2006 08:26 PM
dcjones
Jan 19, 2006 10:54 PM
danimalvt
Engine & Internal
Dec 20, 2005 08:32 PM
luvfroses
Jul 7, 2005 11:44 PM
sully
Jun 8, 2005 08:06 AM
