88 Silverado dies
Old Oct 26, 2010 | 04:10 PM
Blazer-Bill's Avatar
Blazer-Bill is on a distinguished road
Default 88 Silverado dies
1988 K-5 silverado 5.7L TBI Plow truck parked for summer. now trying to prepair for the winter season. it will start then die in just a few seconds!
I have replaced the cap,rotor,wires,plugs and fuel filter. I can hear the fuel pump come up to pressure when the key is in the on position.
what else should I check?????
Old Oct 26, 2010 | 05:32 PM
rriddle3's Avatar
*Moved this to 'The Lounge' since it does not concern a Blazer.*
Old Oct 26, 2010 | 05:47 PM
oktain's Avatar
Check the actual fuel pressure, the pump may still be priming but it may not be able to pump the necessary capacity. It may be something as stupid as a corroded contact creating resistance and the pump doesn't run at full output.
Old Oct 27, 2010 | 05:42 AM
thanks will check that
It is a Blazer...Silverado is the trim package!
gee whiz
Last edited by rriddle3; Oct 27, 2010 at 06:49 AM. Reason: COMBINING CONSECUTIVE POSTS
Old Oct 27, 2010 | 06:48 AM
rriddle3's Avatar
Well - gee whiz - thanks for specifying that.
*Moved to 'Full Size K5 Tech'*
Old Oct 27, 2010 | 08:22 AM
Bad gas? Gummed up fuel injectors?
And we can't read your mind. You must include your vehicle information. Listing a trim package without a base model doesn't cut it.
Old Oct 27, 2010 | 02:17 PM
Z71_Guy's Avatar
Z71_Guy is on a distinguished road
does it just die like you shut it off or does it start to spit and sputter then shut off
Old Oct 27, 2010 | 04:20 PM
bogs and stops, if I pump the pedal like crazy then she'll cough and spit
when checking the fuel pressure what p.s.i. should I be looking for?
Last edited by rriddle3; Oct 27, 2010 at 04:27 PM. Reason: COMBINING CONSECUTIVE POSTS. PLEASE USE THE 'EDIT' BUTTON IF NOBODY HAS REPLIED WITHIN 24 HOURS.
Old Oct 27, 2010 | 05:27 PM
8-10psi
Old Oct 27, 2010 | 08:04 PM
AJBert's Avatar
Originally Posted by swartlkk
8-10psi
I didn't realize TBI ran on such a low pressure. Guess one learns something every day. At least I try to!
STRUCKN
Dec 6, 2008 08:28 AM
Poligono
Nov 3, 2008 06:01 PM
iboweb
Aug 29, 2008 12:15 AM
hayfieldfarm
Engine & Internal
Jan 5, 2007 09:13 AM
2001blazer
Jul 5, 2006 06:19 AM
