89 Front bearings
Old Feb 13, 2013 | 10:27 AM
jmatson's Avatar
jmatson is on a distinguished road
Default 89 Front bearings
I am trying to replace the front wheel bearings. I have Automatic locking hubs. everything i find is telling me to remove the spindle nuts.. I am not seeing those at all.. I got part of the hub out but that's it..
Old Feb 13, 2013 | 10:48 AM
Diaita's Avatar
You haven't removed the inner part of the locking hub in that picture. There is a snap ring that needs to be released to pull the inner hub out. See here. The spindle nut is behind the center piece of the locking hub you see there. You will need a hub socket to remove the inner and outer spindle nut.
Old Feb 13, 2013 | 12:43 PM
abig84's Avatar
yeah... see that little gap on the bottom left (or top left if you open it in a new window) on the inner hub in the picture. there should be two little tabs sticking out facing you. get a pair of pliers and pinch them together then you can slide the rest of the hub out.
also since you are taking those autohubs off, have you considered getting a set of manual hubs? i hate those autohubs, have seen them fail so many times. also encase you havent done so there is a specific socket you need to get those nuts off... sometimes if youre really lucky and they arent that tight you can spin them off with a screwdriver
Old Feb 18, 2013 | 10:02 AM
THePaRaSiTE5771's Avatar
THePaRaSiTE5771 is on a distinguished road
Put on some new brake rotors too.
flat lands blazer
Jul 30, 2010 09:21 PM
alphawolf88
26
Mar 31, 2010 11:45 PM
EnyChevyUK
Mar 21, 2009 07:55 PM
phantom
Aug 21, 2007 06:52 PM
yzf125
Sep 17, 2005 11:45 PM
