92 fullsize Blazer-replacing the starter
Old Oct 27, 2010 | 08:35 PM
gearyr's Avatar
gearyr is on a distinguished road
Default 92 fullsize Blazer-replacing the starter
I know that the starter in my son's Blazer is shot. When you try to start it, the starter is making clicking sounds. Had the battery checked. Battery is good. Hit the starter several times with a hammer. Nothing. What wires do you have to take off the starter? There is one in the front that son is having a hard time getting off. This Blazer is 4WD, a 5.7LT engine, and automatic. My son was trying to get the 2 bottom bolts off. But they are on tight. Going to borrow a air gun and take the bolts off. I know to disconnect the postive battery cabel. Thanks, gearyr
Old Oct 28, 2010 | 06:46 AM
There should be two wires on the starter. The main battery cable and then the smaller solenoid trigger wire. They can be a pain to get removed.
Old Oct 28, 2010 | 09:56 AM
AJBert's Avatar
IIRC, you will need to unbolt the starter first and twist it around to be able to get at the wires. PITA in a tight area but doable.
Old Oct 28, 2010 | 06:19 PM
abig84's Avatar
yeah most these fullsized blazers that ive messed with have more then enough wire. on my current truck i can actually rest it on the front axle while i disconnect the wires. though my stuff is older
jdmmario
Oct 25, 2014 06:25 PM
nualp
Mar 9, 2011 10:36 PM
cage47
Aug 8, 2010 08:21 AM
Miget_in_japan
May 27, 2008 11:56 PM
CodyT
Mar 20, 2008 03:31 PM
