front hubs
Old Jun 27, 2010 | 12:25 PM
blrob5's Avatar
blrob5 is on a distinguished road
Default front hubs
I think the left front hub on my 92 is bad. Anyway of knowing for sure once I get it jacked up? I get a nice thumping sound when turning a corner, sounds like metal on metal. I thought when a hub goes bad, you usually hear a grinding sound. Any thoughts? Thanks in advance for your help!
Old Jul 4, 2010 | 11:14 AM
They can sometimes be tricky. When driving down the road, does the noise go away when you turn to the left? Does it get worse when turning to the right? If the answer to both of those questions is yes, then the left wheel bearing assembly is the likely culprit.
If it is really bad, you should feel play in the bearing.
Barney
Sep 13, 2010 06:03 AM
mcblaze
Oct 21, 2009 03:32 PM
Baja Blazer 85
Sep 6, 2009 07:51 PM
Chevyguy032
May 1, 2008 11:09 AM
phantom
Aug 21, 2007 06:52 PM
