Coolant on Block?
Old Jan 23, 2007 | 04:22 PM
Chevyguy032's Avatar
Chevyguy032 is an unknown quantity at this point
Default RE: Coolant on Block?
wouldnt it just be easer to tap it than out in Heli Coils?
Old Jan 23, 2007 | 08:54 PM
It all depends on if you have the material there to go larger. In your case, you should be able to step up to the next larger size. If you do not have the extra material, or do not have the room for the head of a larger bolt (and don't have access to socket headed cap screws, etc), then Helicoil is an excellent alternative.
Just for some additional information, we use Helicoils in many of our fixtures in our large CNC machining centers. Reason, the threads wear out. With helicoils, we can just remove the coil and put in a new one.
Old Jan 24, 2007 | 03:53 AM
Chevy Lover's Avatar
Another benefit to using heli coils is thet you still have the bolt with the same thread.
helo
Oct 29, 2019 07:56 AM
Skeeter Cruz
Mar 4, 2010 07:07 PM
lil_blazin
May 10, 2009 05:20 PM
N.alaska_blazer
Feb 23, 2009 01:31 PM
kerander
Apr 12, 2007 04:29 PM
