"D" or "OD"
Old 11-07-2011, 09:15 PM
k5bmr's Avatar
k5bmr is on a distinguished road
Default "D" or "OD"
Ok, boys and girls. The '85 350 stumbles and bumbles in "OD". I have to keep pumping the gas pedal just to keep it going. However, if I'm in "D", it runs a whole lot better, no hesitation, I don't have to keep on pumping the pedal to keep it going. Thoughts and ideas, please. Thanks.
Old 11-07-2011, 10:00 PM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
HMMMMMM. im guessing you mean it stumbles while say your cruising 55 mph in 4th gear? My guess is you have carb issues and its not liking the low rpm of the 4th gear much. You said you have to pump the pedal....I say its the carb needing rebuilt.
Old 11-08-2011, 07:06 AM
Z71_Guy's Avatar
Z71_Guy is on a distinguished road
well if its while cruising it could be a torque converter issue or a TV cable issue,
Old 11-08-2011, 05:29 PM
abig84's Avatar
i had a beater s10 that had a similar issue, you can never just cruise with it, always had to be down a gear and have some rpms up. ended up being a issue with the accelerator pump in the carburetor for whatever reason it was allowing excess gas into the engine. just something to look into
Old 11-08-2011, 08:07 PM
chris015's Avatar
read what abig84 said below you.
Exactly. I had a carb'd truck with od and it hated the low rpm's until i had the carb rebuilt.
Old 11-08-2011, 08:10 PM
Z71_Guy's Avatar
Im just giving other possibilities no need to be like that. I work at a shop and its not always the common thing that make a problem happen.
Old 11-08-2011, 08:28 PM
chris015's Avatar
Yea,those could be the problem too. and by the way,i didnt reply to you in a "douche bag" manner. No disrespect intended at all
Old 11-11-2011, 05:30 PM
k5bmr's Avatar
Can I just drive the damn thing in "D" and be done with it, or will it screw up something else???
Old 11-11-2011, 05:49 PM
chris015's Avatar
if it drives good in drive,go for it. you will just have some crappy gas mileage. but some awesome throttle response. lol but if its stumbling in od, and its the carb,one day or another its gonna do it in drive....id start calling around some old corner carb shops and see about a carb rebuild.
Old 11-11-2011, 06:04 PM
xgiovannix12's Avatar
I use drive when i tow my trailer
gives me a lot of rear end torque and feels like theres an engine brake going down hills
Like the big rigs have !
Quick Reply: "D" or "OD"
