driveshaft help!!!!
Old Dec 26, 2011 | 05:11 PM
87k5blazerbrat's Avatar
87k5blazerbrat is on a distinguished road
Exclamation driveshaft help!!!!
hey guys i have a question . ive got an 87 k5 lifted 6inches has a dana 60 in the rear not sure of the transfer case but it does has a drop kit on it. here is my problem the kid i got the truck from had the rear shaft custom made the proceeded to twist the joint to hell and back, ive taken it to a larger drive shat place here in ct and they said they wont touch it. any ideas on what i should do or bring this thing to be fixed? any help would be great ! i have some pics of the shaft not sure how to put them up tho
Old Dec 26, 2011 | 05:23 PM
xgiovannix12's Avatar
to post pictures you can use this icon
you need to post a link of the photo its self for example a photo bucket direct link
Old Dec 26, 2011 | 06:46 PM
LJLtrucking's Avatar
LJLtrucking is on a distinguished road
sounds like you need to get a cv joint at the rear end like they used on fullsized cadillacs back in the day.
Old Dec 26, 2011 | 08:06 PM
abig84's Avatar
wonder if you can just throw a stock one in. ive ran stock shafts with 6inchs of lift for years.
Old Dec 26, 2011 | 09:11 PM
i was thinking about the stock shaft but i cant find a conversion joint to go to a dana 60 to a chevy shaft. when u run a stock shaft should i run the transfer case drop or no?
i am having a problem finding a shop that will even attempt to make a new shaft, Ive had them tell me to take out the lift :-\
Last edited by swartlkk; Dec 27, 2011 at 08:49 AM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Dec 27, 2011 | 10:08 AM
Are you sure you have a Dana-60 rear axle in your truck? If so, how wide is the yoke? It likely will be a 1350 u-joint, but there are 1310 joint Dana-60's out there.
1350 Spicer Specs:
1.19 Bearing Cup Diameter - 3.62 Overall Width
1310 Spicer Specs:
1.06 Bearing Cup Diameter - 3.22 Overall Width
Saginaw S44 Specs (2-3011):
1.13 Bearing Cup Diameter - 2.56 Overall Width
For conversion u-joints, consult the Neapco U-Joint Reference Guide.
As far as the rear driveshaft goes, it sounds like you need a new one made up. Here are a few links that might help you out:
Denny's 4x4 Driveshafts
Tom Wood's Custom Driveshafts
Plus more on google...
If you still have the stock slip yoke at the back of your transfer case (likely the NP208), you will definitely want to look into getting a slip yoke eliminator to put a fixed yoke at the back of the t-case. A lot of people get a Dodge NP208 that already has a fixed rear yoke and swap the output shafts, but I believe that there are kits available to do this as well. To go the Dodge route, the transfer case needs to be removed and pretty much gutted so now would be a good time to check out all of the bearings & seals. Not sure what's available in kit form. The Dodge NP208 w/ fixed rear yoke is by far the most common swap in this regard because it shortens the transfer case by ~6" making the driveshaft angles less harsh.
Old Dec 29, 2011 | 06:29 PM
abig84's Avatar
they sell universal ujoints for basically everything. it just sucks trying to find the right part number.
Old Dec 29, 2011 | 09:16 PM
ericthughes's Avatar
ericthughes is on a distinguished road
would you have this same problem putting an 8in lif on a 78
1992ChevyBlazer
Mar 10, 2014 01:22 PM
gitch93
Jan 23, 2013 04:51 PM
chevyman07
Sep 24, 2006 08:19 PM
trudynosports
Dec 13, 2005 09:40 PM
irocman
Nov 4, 2005 09:44 AM
