emergency front actuator question on a 94 blazer
Old Feb 5, 2010 | 07:59 PM
gmoney30's Avatar
gmoney30 is on a distinguished road
Default emergency front actuator question on a 94 blazer
i need four wheel drive like asap we have a blizzard that just started in Maryland and i was wondering is there anyway i can take the actuator out and place a object in the axle hole and then screw the actuator back in to make it permanant 4x4 until the snow is over, and if so what would you suggest that would be just about the right size to make it engage and also have the actuator screw all the way in, please someone help me, i havent replaced the brown wire going to the actuator yet
Attached Thumbnails emergency front actuator question on a 94 blazer-img01219.jpg
Old Feb 6, 2010 | 01:32 PM
gmoney30's Avatar
Default weather update
this was taken a few hours ago
Attached Thumbnails emergency front actuator question on a 94 blazer-img01222.jpg
Old Feb 6, 2010 | 01:36 PM
I can't remember what it looks into inside there... If it is a relatively contained area, you could try to make up something to stick in there. The actuator just pushes in on a shift fork inside.
Old Feb 6, 2010 | 01:44 PM
gmoney30's Avatar
Default thanks for the reply
can you tell me about how far does the actuator come out when engaged
Old Feb 6, 2010 | 01:45 PM
Probably 3/4 to 1" total.
Old Feb 6, 2010 | 01:53 PM
gmoney30's Avatar
ok im going to try it and let you know what happened
Old Feb 6, 2010 | 06:29 PM
gmoney30's Avatar
I have great news I put a little socket in the axle and then twisted the actuator in and it works like a charm now
Old Feb 6, 2010 | 06:32 PM
oisinirish's Avatar
Good deal...just don't forget about it. LOL.
Old Feb 6, 2010 | 06:35 PM
Yeah, I wouldn't go leaving it in there long term. Your mileage will suffer. But at least you have 4wd now!
Old Feb 6, 2010 | 07:58 PM
gmoney30's Avatar
Yea I know, as soon as this blizzard clears I'm going to take the socket out and then try to troubleshoot to find out if its the actuator or the wires not being connected right, I really need to know if the brown wire from the transfer case switch is spliced with another brown wire
RJ2004
Dec 4, 2013 09:41 AM
a2dadamm
Nov 19, 2012 08:44 AM
HiRidinChevy93
Apr 27, 2011 07:29 AM
markrd
May 8, 2009 01:39 PM
Lckyctch
Feb 1, 2007 09:50 AM
