full size jimmy body to blazer
Old Jul 1, 2009 | 04:12 PM
Magius's Avatar
Magius is on a distinguished road
Default full size jimmy body to blazer
So, as some of you may have noticed from my intro post i am the proud owner of a 78 K5. well, the body is almost completely shot. I have found a mid 80's full size jimmy tub that is like brand new. From the research i have done, it seems 73 to 91 blazers can pretty much use the same body tubs.
Being that there is a wide range of knowledge here on these forums, i need your help. will this work and can the bodies be lifted manually say by... 5 or 10 people? anything i need be aware of?
Magius
Old Jul 13, 2009 | 08:27 PM
bluefulltop1975's Avatar
bluefulltop1975 is on a distinguished road
with the help of some friends it should fit right on
Old Jul 13, 2009 | 09:34 PM
There were changes in the body mounts through the years. 73-77, 78-80, 81-84, and 85-91 where the year ranges having the same body mounts from beginning to end.
The rear two mounts are the same from 73-91.
The radiator core support mounts and the front tub mounts are the same from 73-80 and then from 81-91.
The #2 mount (the mount just ahead of the rear axle) is the one that changes the most with ranges of 73-77, 78-80, 81-84, and 85-91.
Not only do the mounts change in design in these ranges, but also in height. I am unsure if the changes were accommodated in the body or in the frame. You will have to make a datum and compare the height of the various mounting surfaces frame to frame and body to body to know for sure. Hopefully it is all in one component allowing you to use factory mounts.
THIS PAGE from LMCTruck.com shows the breakdown.
admathi
Dec 15, 2019 04:24 PM
JimmyMac13
Apr 23, 2011 11:26 PM
goerzenl
Nov 1, 2010 10:14 PM
gabegmc
Suspension Tech
Jul 21, 2010 05:16 PM
CarefulBandit
Jul 2, 2010 01:17 PM
