Hesitation
Old Oct 23, 2009 | 11:40 AM
Straka88's Avatar
Straka88 is an unknown quantity at this point
Default Hesitation
My 1988 Blazer is starting to hesitate when I step on the gas and I noticed the pick up and power is not like it used to be. Any ideas to what might be the cause. I'm trying to get it ready for a Elk hunting trip in Montana in November. Won't be able to make it if my Rig isn't running right. I replaced my plugs, plugs wires. pvc valve, O2 sensor, fuel filter, New intake system, Headers and exhaust system. Thanks for all and any help.
Old Oct 23, 2009 | 11:51 AM
It is possible that the EGR valve is not functioning correctly. It is also possible that your injectors are not putting out the correct spray pattern, affecting the efficiency of the engine.
Old Oct 24, 2009 | 11:18 AM
steechfinger's Avatar
steechfinger is on a distinguished road
did you replace the fuel filter in the tank. and run some 92 with octane booster to clean out your injectors. also check for a vacume leak somewhere
Old Nov 7, 2009 | 11:22 PM
Straka88's Avatar
I found that my distrubutor cap was not sitting corretly on the distributor and that there was some pieces broken on the distributor as well. Think it might have been the stator. Ordered a New Accel HEI distributor but have not put on yet. I'm hoping that this will fix my crappy running issues.
Old Nov 12, 2009 | 11:41 AM
Straka88's Avatar
Well for any one that just wants to know, I installed a new distributor and my Blazer run awesome. But if its not one things its another. Heard one of my headers gasket blow out and then my engine light came on. I hope its because of my exhaust leak.
Old Nov 12, 2009 | 02:03 PM
Sounds good on the distributor. Not so good on the header gasket though...
thebaf
Engine & Internal
May 18, 2006 01:08 AM
blazergirl15
May 15, 2006 12:13 AM
black19
Engine & Internal
Feb 22, 2006 12:13 AM
wahhen
Jun 10, 2005 10:56 PM
jp5162
Mar 1, 2005 10:11 PM
