How do I know if I have R-12 or R-134?
R-12 used a Schader with threads to screw a gauge etc on both the high & low sides. There is a valve core just like a tire has. The R134A use a a clip on type valve. You will see a ball that pushes in.
If it has been converted it should have a tag stating so. That is required if it was done professionally.
In this picture the person is holding a r134a fitting just above a r12 fitting. If you have r12 simply use a adaptor kit with a fitting like the red one and convert it over. Google is your friend on how to convert it over if ya need help with that.
brettf516
Nov 9, 2011 08:58 AM
livlifes2short
Mar 13, 2009 11:26 PM
flowmasta
Jul 26, 2006 01:16 AM
