Ignition Noises
Old May 23, 2010 | 07:37 AM
yarinzim's Avatar
yarinzim is on a distinguished road
Default Ignition Noises
hello!
blazer k5 90 - when i start my truck i can hear a noise that sounds like an electric shocker pops, and if I'm not mistaken the ignition time is a bit longer than usual. any thoughts?
Old May 23, 2010 | 01:16 PM
Have you looked for spark escaping from the wires and/or distributor cap? Doing so at night will likely lead you to the problem.
Old May 23, 2010 | 10:33 PM
yarinzim's Avatar
i will make a night check. another thing i forgot to mention is that i connected a sort of a safety switch to the starter relay. the connections are good though.
is it possible that there's a link between this modification to the noise I'm hearing?
Old May 24, 2010 | 06:15 AM
Try removing your switch and see if the problem persists. Pretty easy to rule out.
Old May 24, 2010 | 09:22 AM
yarinzim's Avatar
maybe i didn't clarify. i know how to rule out the switch. my question was if I'm making any trouble to the relay by adding up a switch or there shouldn't be any problem?
Old May 24, 2010 | 11:23 AM
As with anything, if done improperly or inferior parts were used, the end result will not be as intended. Switching the starter solenoid shouldn't be a problem if done correctly and with parts that can stand up to the load of the solenoid. You really should test the load that the solenoid draws and ensure that your switch is capable of withstanding that load repeatedly.
Old May 30, 2010 | 10:20 PM
yarinzim's Avatar
ok guys, it turned out to be a loose connection of the safety switch i guess. i reconnected the wires properly and the noises stoped.
thanks for the replays and the help, Yarin.
Brian5792
Oct 24, 2018 11:34 AM
bdscholes71`
Oct 7, 2007 02:59 PM
frankjc
Feb 11, 2007 09:04 PM
drefda
Oct 4, 2006 05:31 PM
2001blazer
Mar 29, 2006 01:51 AM
