Knock!
Old Sep 16, 2010 | 06:02 PM
DANGLE1976's Avatar
DANGLE1976 is on a distinguished road
Default Knock!
I HAVE A94 CHEVY BLAZER FULLSIZE...WHEN I START THE TRUCK IT MAKES A STRANGE SOUND BUT DOESNT KNOCK.WHEN I GIVE IT SOME GAS IT MAKES A KNOCKING SOUND CLOSE TO THE FIRE WALL.A FRIEND TOLD ME IT SOUNDED LIKE A MAIN BEARING WAS GONE.WHAY COULD IT POSSIBLE BE THANKS!
Old Sep 19, 2010 | 01:29 AM
abig84's Avatar
Sometimes a cracked flexplate will cause a knocking sound. Pull off the inspection cover and look really close. Also see if your trans came lose off the engine that's how mine cracked
Old Sep 19, 2010 | 06:56 PM
DANGLE1976's Avatar
I was told that also....where is that located?...i was told to look at the flywheel,main bearing..etc....thanks!
Old Dec 15, 2010 | 12:16 AM
DANGLE1976's Avatar
Well it looks like i have to replace the engine....a complete rebuild is gonna cost 1100!..is this a good price to rebuild my old engine?
Old Dec 15, 2010 | 09:23 AM
Deatherage's Avatar
Deatherage is on a distinguished road
Thats a tough question to answer without all of the specifics. First, is your truck at a shop now? If so, then have they torn it down? If they have then what, specificly did they write it up for? there are several possibilities, and they all matter. A complete rebuild is sort of vague because there are several different things that may or may not need to be done.
Do you have any of the details?
Old Dec 18, 2010 | 12:07 AM
DANGLE1976's Avatar
Truck is still in the yard..calling around geting price quotes...motor is still in truck.had a guy look at it and he told me to replace the motor...said it had a piston knock from a loose bearing!..just bought the truck don't know the motor well enough so just figured i'd have the motor rebuilt...
Old Dec 18, 2010 | 09:38 AM
abig84's Avatar
it MIGHT be possible just to replace the bearing if you didnt drive it to long and oval off the crank. but im guessing you probably have to pull the engine to remove the pan anyways. ive done that in the past with a offroad truck. just dropped the pain threw out the spun bearings put new ones in and the engine was fine. tried it a different time where the guy drove like that for a while and it ovaled the crank and was nothing you could do
Old Dec 19, 2010 | 11:25 AM
DANGLE1976's Avatar
So is 1100 a good price for the total rebuild?..the guy said it would basically move the mileage of the engine to 0...just wondering if the price was too high...
Old Dec 19, 2010 | 02:29 PM
If you only need to replace the bearings, gaskets, rings, etc, and do a cylinder hone, $1100 to drop it off and pick it up, that seems high to me, but might not be too bad depending on where you are located. If parts need to be replaced, then it's probably a good price.
Old Dec 20, 2010 | 11:51 AM
DANGLE1976's Avatar
I live in ohio...so for a complete rebuild thats too high?...thanks!
fredguaz
Dec 11, 2017 08:11 AM
ejschultz
May 23, 2009 04:15 PM
Talusgirl
Apr 28, 2008 08:34 PM
93LT
Jan 9, 2006 09:25 PM
dwoftx
Jul 10, 2005 06:47 PM
