Parking break light
Old Oct 8, 2011 | 09:03 PM
Dano01's Avatar
Dano01 is on a distinguished road
Default Parking break light
I have a 1990 GMC Jimmy 5.7l with 144,000 miles. Today i started the vehicle and the parking break light with the (P)(!) on all the time. i was wondering what could be the problem. i read the other post that have been posted and none have the same problem.
I was wondering if anybody has an idea where i should start looking.
Thanks.
Old Oct 8, 2011 | 09:07 PM
xgiovannix12's Avatar
you might have a brake problem and its warning you
How do your brakes work ?
Check your brake fluid maybe its low
check for leaks
Old Oct 8, 2011 | 09:23 PM
Dano01's Avatar
brakes work good. will check for leaks and low fluid.
Old Oct 9, 2011 | 01:57 AM
DaddysBlazer's Avatar
DaddysBlazer is an unknown quantity at this point
I have tinted breaklights and I have poeplke all the time telling me my break lights dont work. haha Im actully looking for some of those that come tinted from the factory.
Old Oct 9, 2011 | 09:07 AM
Z71_Guy's Avatar
Z71_Guy is on a distinguished road
im going to guess its your rear wheel cylinders leaking, or a line
Old Oct 9, 2011 | 07:52 PM
THePaRaSiTE5771's Avatar
THePaRaSiTE5771 is on a distinguished road
The main reason the brake warning light will come on in an 89-91 K5 is due to unequal pressure in the brake lines, or the ABS computer is malfunctioning. I bet your rear wheel cylinders need to be replaced. If the fluid in the master cylinder is full, then unplug the two connections on the back of the ABS module (the black box next to the master cylinder). Turn the ignition to the "on" position for about 5 seconds. Then shut off the key, reconnect those two plugs on the back of the ABS module and turn the key on again. Is the brake light still on?
Old Oct 9, 2011 | 07:53 PM
whats this gotta do with his problem ?
cleburne red
Oct 18, 2011 07:11 PM
davedidit
Aug 2, 2011 07:49 PM
yarinzim
Jul 19, 2009 11:44 AM
BIG SURF
Mar 19, 2009 03:18 PM
XtreeX
May 9, 2007 01:11 PM
