radiator
Please keep in mind that without a picture I'm not sure how your rad is layed out.
From top to bottom...PS
Rad cap & just under that would/could be the over flow hose going to a reservoir.
2 trans cooler lines, 1 input, 1 output.
Lower rad hose near the bottom that leads to the bottom of the water pump.
On the other side (DS) there should be (again from top to bottom.)
Coming from thermostat housing (top front of the manifold where the thermostat is housed) to the rad, is a coolant line near the top.
2 engine oil cooler lines.
Get some pics please of your set-up.
That's an odd set-up to me. A heater core hose right off the rad? I can see the trans cooler lines & 1 has been modified, so I'm going out on a limb & saying that rad is not stock to that truck.
On the DS what's that tube that isn't attached to anything? If there's another I'd say they're for the engine oil cooler.
<EDIT>
Ok so I found one with the heater return line:
Rows3Outlet1 9/16 Inlet Connection1 5/16-1 9/16 Top LeftOutlet Connection1 9/16 Bottom RightMountingChannelTrans Oil Cooler8 CommentsHeater Return Line & Coolant Level Sensor on RH Tank
That's what they say the connection sizes are.
The one you ordered seems like the right size for the core & hoses but you didn't mention if it has the heater return outlet.
<EDIT>
Forums are for learning and sharing information...
To the OP, don't let one rotten apple ruin your experience here!
bigdaddykane93
01-04-2010 12:03 PM
FLcruising
07-04-2005 02:51 PM
