simple belt question
Old Aug 5, 2011 | 09:10 PM
wornknobby3's Avatar
wornknobby3 is on a distinguished road
Default simple belt question
does anyone know if they make a serp belt that will go onto the crank, alternator, p/s, w/p, ONLY? and eliminate all the other pulley's on the right side of the motor.... it would eliminate the entire passenger side bracket
Old Aug 5, 2011 | 09:15 PM
xgiovannix12's Avatar
give us some more information on the truck so we could answer your question
Old Aug 6, 2011 | 08:01 PM
sorry boss, 89 K5 w/ 350 SBC, i've been looking at local parts stores but it seems it makes it difficult to make sure the pully's spin the right direction once i start removing so many pully's unless i get just brakets with pully's
Old Aug 7, 2011 | 10:45 AM
abig84's Avatar
for future reference you can pretty much get any size belt you want. when i illiminated the smog pump on my 85 they didnt make a belt so i just had to keep guessing. and after about 10 tries i got one that fit. they go in basically 1/2 inch intervals so you can usually find one that fits
Old Aug 7, 2011 | 11:51 AM
Take a piece of 1/2" wide webbing and wrap the pulleys you will be keeping while holding the tensioner at about midway through it's range of motion. Mark the webbing where it overlaps and then measure the length. That'll get you in the ball park.
As far as direction of accessories goes, that shouldn't be a problem. Any accessory with a grooved pulley will turn in the same direction as the crank regardless.
lionel2
Sep 7, 2012 02:45 PM
adaptechsolution
Apr 7, 2012 12:03 PM
mudsliner
Nov 26, 2006 12:56 AM
4WDBlaze
Engine & Internal
Oct 20, 2005 12:05 PM
