Three Questions
Old Jun 15, 2009 | 11:34 PM
yarinzim's Avatar
yarinzim is on a distinguished road
Default Three Questions
Hello Everybody! i have some questions for you (Blazer K5 1990)
1. my tranny jumps between the third and the fourth gear when i'm at cruising speed, if i apply more gas it stops. someone spoke with me about the kickdown but i don't know what i need to do.
2. my wipers are working at the same rate no matter how i turn the stick. and it doesn't stop unless i stop it with the reverse mode at the start.
i have no idea what component controls it.
3. my road lights are working fine but when i'm trying to switch to high lights it sometimes works and sometimes i need to give it a few trys. is there a problem with my lights controller that located behinde the dash?
thanks in advance, Yarin.
Old Jun 16, 2009 | 08:00 PM
#2 & #3 would both be controlled by the multifunction switch. It is possible that the switch is bad.
For #1, it is possible that the TV cable is not adjusted properly. Run a Google search for 700R4 TV adjustment and you should find more than enough information.
Old Jun 16, 2009 | 08:23 PM
bandidolenny's Avatar
What size tires and what gear ratios are you running? Try only putting it in overdrive when traveling at highway speeds and having a lightly loaded engine. If you give it more than about a quarter throttle then it will unlock the converter everytime.
Old Jun 19, 2009 | 10:50 AM
yarinzim's Avatar
sorry for the delayed response guys. i'm running on 33' tires and 4.56 gear ratio. actually the problem usually occurs on inclided roads. so when i give it more gas it drives o.k. but im sure this is not the way to fix this, you think i should try and adjust the TV cable?
by the way - the multifunction switch controls the lights and the wipers as well or is it a different multifunction switch?
thanks in advance, yarin.
Old Jun 19, 2009 | 02:46 PM
33" tires and 4.56 gear ratios are a good setup and shouldn't cause your tranny to constantly downshift. I would take Kyle's advice and look at the tv cable.
Old Jun 20, 2009 | 05:44 AM
yarinzim's Avatar
OK - i'll give it a try and i'll report back how it went.
thanks.
Ugly_Monkey
Mar 19, 2010 07:31 PM
ExplicitYourSelf
Oct 13, 2009 10:18 AM
nimrodcs
Dec 27, 2008 03:54 PM
BlazerBrendan
Oct 12, 2008 09:12 PM
riceh8r0512
Jun 8, 2008 08:12 AM
