Which is the Timing Wire???
Old 09-10-2008, 06:51 AM
alamantia's Avatar
alamantia is an unknown quantity at this point
Default Which is the Timing Wire???
1992 K1500 Blazer 350 TBI
To set base timing I thought I was supposed to disconnect a tan wire. I open the hood and see a big wire loom coming up from the firewall from under the master cylinder and going over the back of thedrivers side valve cover to the back of the intake manifold where wires branch out to the TBI, DIST, MAP, ETC. On the outside of this loom is a black wire coming from the fire wall under the master cylinder to a disconnect and from the other side of the disconnect is a purple wire going to the back of the manifold by the distributor. Is it the purprle wire that I am supposed to disconnect?
[IMG]local://upfiles/3108/8A597AE813314ADAAE6FC8A05A8DBCB1.jpg[/IMG]
[IMG]local://upfiles/3108/A19A942EB78C4E3A818B24F953358035.jpg[/IMG]
Old 09-10-2008, 03:50 PM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
Default RE: Which is the Timing Wire???
Should be a tan wire with a black tracer. should be a big plastic connector that unplugs.
This is what mine looks like
Old 09-11-2008, 06:34 AM
alamantia's Avatar
thanks bro, i wonder what the purple one is for then...
Neenie217
07-25-2014 02:19 PM
Brendynj18
04-20-2011 09:59 PM
southernsteel87
09-11-2010 09:41 AM
zedartwo
12-18-2009 09:52 PM
ginobass
06-26-2007 02:39 PM
Quick Reply: Which is the Timing Wire???
