Transmission shifting
Old May 26, 2011 | 12:42 PM
cmickey12's Avatar
cmickey12 is on a distinguished road
Default Transmission shifting
I have a 84 blazer Siverado and i have an issue with it hard shifting into 2d gear at 20MPH.......why and what would be the cause i believe it has a 400t in it. Can someone help me out....please
Old May 26, 2011 | 12:55 PM
rriddle3's Avatar
*Moved to 'Full Size K5 Tech'*
Old May 26, 2011 | 10:27 PM
chris015's Avatar
Could be a number of things. 1st off id start with the basics. Fluid & filter change,change the vacuum actuator and Check the Governor gear. this should help with the hard shifting into 2nd. about the hard shifting into gear,ehhh..do the filter change 1st.
Old May 27, 2011 | 07:27 AM
Z71_Guy's Avatar
Z71_Guy is on a distinguished road
I believe That blazer would have had the 700R4 in it it unless someone swapped it out
here is a link with pictures of the trannys and there pans
General Motors | GM | Automatic Transmission Identification Chart
1997liftedblazer
May 22, 2009 11:11 AM
troyky29
Aug 15, 2008 01:03 PM
hmdmom2
Dec 6, 2007 09:25 PM
S10Blazer
Nov 13, 2007 01:34 PM
96jimmy4x4in
Oct 7, 2007 09:23 PM
