What trans do I have in my blazer
Old Jan 4, 2007 | 12:04 PM
alamantia's Avatar
alamantia is an unknown quantity at this point
Default What trans do I have in my blazer
My 1992 K1500 Blazer,it has a 700R4 right?
Old Jan 4, 2007 | 12:44 PM
Chevy Lover's Avatar
Default RE: What trans do I have in my blazer
Probably. if it's a 4 speed automatic..
Old Jan 4, 2007 | 11:22 PM
alamantia's Avatar
yes, its a Auto w/ overdrive, thanks
Old Jan 5, 2007 | 01:49 AM
Mapoftazifosho's Avatar
Mapoftazifosho is an unknown quantity at this point
So do all the newer ones have the 4L60-E?
Old Jan 5, 2007 | 02:28 AM
ORIGINAL: Mapoftazifosho
Up til 2002. 2003 to 2005 you could have a 4L60-E or a 4L65-E
Old Jan 5, 2007 | 07:52 PM
alamantia's Avatar
that could begood news cause there is something wrong with my trans, i think its just a check valve sticking in the valve body but what do i know? I have a 4L60-E from an old camaro i had, im wondering if I can reuse the current Blazer converter and swap tail shafts to adapt to the transfer case, anyone know? Sounds lodgical right, until i get it apart and try lifting up the camaro trans to the truck.....
Old Jan 5, 2007 | 11:57 PM
20Blazer00's Avatar
Nice Tahoe/Blazer, that might work but you might check the output shaft spline count, even though the cases would bolt up the internal shaft may not mate up to the transfer case input shaft and seal??? but that is just from thinking to much. Check with your local tranny shop to find out the clear answer...
Old Jan 6, 2007 | 04:09 AM
Hanr3's Avatar
You will have to change the output shaft on the tranny from the 2wdr version to the 4wdr version to bolt ont eh t-case, plus take off the tailhousing and put on the t-case adapter. Otherwise its a direct bolt on.
Old Jan 6, 2007 | 11:11 PM
alamantia's Avatar
you guys are all alright... this is only my third truck, all my other vehicals have been camao's old and new,amonte carlo SS, a cutlass 442etc... My other two previoustrucks were my 1986 K20 pick up (my favorite) and some **** *** 1988 S-10 4WD Blazer with a 2.8 and I must say i enjoy working on the trucks much more than my cars, well aside from that day / weekend i thoulght it would be a good idea to tackle all four ball joints in my K-20 that is.... My dads dealership deals with a trans shop and i sort of know the guy there (through my father) i will go speak to him about getting me the parts.
I asume the imput shafts are the same, same splines in a camaro converter to a Blazer converter? I ask becausei plan on reusing the blazer converter
Thanks again for all your advice.
Old Jan 7, 2007 | 10:55 PM
Hanr3's Avatar
Taht Is dont know. ask the tranny guy. He will know. He shoudl also have a spare 4wdr output shaft or two laying around the shop too. Around here you can pick them up for less hten $20. No doubt he could do the swap for ya as well. Its not hard, you just have to remove the bguts of the tranny to do it.
88s10Blazer
Dec 8, 2024 03:31 PM
ksunday1
Nov 5, 2013 02:22 AM
janet7
May 24, 2011 02:16 PM
86blazeder
Feb 24, 2009 07:33 PM
rob1621
Feb 29, 2008 08:15 PM
