YAYY..first problem...
Old Dec 2, 2006 | 01:30 PM
Chevyguy032's Avatar
Chevyguy032 is an unknown quantity at this point
Default RE: YAYY..first problem...
now iam hearing check my fuel pump relay...how can i check this?? and i cant find a damn fuel pressure test kit anywhere..the only one i ofund says it is for most multi-port fuel injection vechicles..would this one still work??
Old Dec 2, 2006 | 04:04 PM
20Blazer00's Avatar
If the test kit will connect with your fuel system and the gauge will read as low as 0psi then you should be able to use it. But make sure of the return policy for the store if it is not and unopened.
Relay location could be on the firewall but not sure if in the engine compartment or behind glove box. Another location might be near the pump or tank????
Old Dec 5, 2006 | 01:23 AM
ok i didnt have the time to work on it so i took it to my mechanic..yea the problem was no fuel injector pulse so he replaced the injectors....
pio
May 20, 2015 06:29 AM
bigchevyguy
Jul 17, 2014 12:46 PM
77Nova
Aug 28, 2010 10:38 AM
new2blazers
Jan 11, 2010 09:40 PM
thefloridian
Sep 28, 2009 10:25 AM
