Tailgate window will not roll up
Old 10-07-2009, 08:45 PM
kwerts's Avatar
kwerts is on a distinguished road
Default Tailgate window will not roll up
I have a 1990 full size Blazer and the tailgate window will not roll up. I replaced the switch several months ago and it worked for a while. The problem has surfaced again. I have had the switch checked and it checked out as good. Does anyone have a diagram of the wiring so i can trace the wires from the switch in the dash to the motor in the tailgate?
Thanks
Old 10-08-2009, 12:14 AM
old skool luvr's Avatar
for starters kwerts, you're in the wrong section. you K5 boys have a section right below the 2nd gen section. but since i have a '90 'Burb with a tail gate, i'll give ya a heads up-get a new motor. i would have a periodic issue with the window going up. replaced the switch was fine for 3 weeks, then absolutely nothing! the motor worked, but was so damn weak, it couldn't lift the weight of the window. bought a new one from GM (not to bad, was just under $100 CAN, taxes in), comes with 1 yr warrenty, and is alot faster now.
Old 10-08-2009, 05:57 AM
*Moved to Fullsize Tech*
I agree, the motor is the likely cause. The reason why the new switch works for a bit is because it is new and will not have as high of a voltage/current hit when activated. The motor is the most likely cause of the whole thing. All that you really have to do is test for proper voltage at the motor. When you press up, the tan with white stripe wire should be hot. When you press down, the light blue wire should be hot.
Old 10-08-2009, 06:33 PM
kwerts's Avatar
Thanks guys - i did replace the motor with a used motor last year. But i will check the motor again since the one i put in was used. Appreciate your feedback.
Old 10-15-2009, 12:59 AM
89k5steal is on a distinguished road
I just posted this on another question. There is a safety switch on the drivers side latch inside the tail gate. it will not allow it to go up when the tailgate is down. I had this problem and was about to replace my motor when i found 2 blue wires that acts like a ground for the motors up switch. If you take the taligate fover off you should be able to see the wires over on the latch mechanism. Try that and let me know.
Old 10-16-2009, 01:18 AM
kwerts problem sounded more like the motor was shot (judging from what he wrote).
are you trying to say your safety switch wires were corroded, and caused your window to freeze?
Old 10-16-2009, 09:21 AM
abig84's Avatar
ive always just bypassed the safety switch, just make sure that window is all the way down before you open it. to test the motor just run a hot wire all the way from your battery and touch it to either wire to see if it goes up and down. also... you can try running a ground all the way from the battery, ive had it happen before where the motor wasnt grounding.
Old 11-04-2009, 06:00 AM
rick fernandes is on a distinguished road
im looking to by a cable drive for tailgate window 1989 chevy blazer full size i look on line, i cant find one. i appreciat thanks
Old 11-04-2009, 07:13 AM
LMC Truck sells them... ~#30 for the drive cable.
RobRad
03-24-2014 06:08 PM
someone11
05-10-2013 06:23 AM
GP1
03-21-2012 01:34 AM
Little Roober
03-23-2011 12:22 AM
burt
09-02-2008 02:15 PM
Quick Reply: Tailgate window will not roll up
