01 blazer is leaking atf
i have an 01 blazer and it is leaking atf. i dont have the money to fix it right now so i am filling the atf and keeping it full what would be the worst that could happen if i dont get it fixed right away?
worst case... you run out of fluid and destroy the transmission costing you upwards of 1200-1700 to fix.... (if you have someone do it for you)
if its a cooler line/fitting, just shell out the $50-100 to have it fixed or fix it yourself, same for a leaking pan gasket. will save you lots of money in the long run.
jnail
01-05-2013 02:55 AM
96jimmyslt4x4
06-11-2011 01:01 AM
vassago41301
01-26-2007 04:58 AM
