1996 4x4 blaze oil line delete
Old Mar 10, 2025 | 03:45 PM
47lougean's Avatar
47lougean is on a distinguished road
Default 1996 4x4 blaze oil line delete
i finally deleted my oil cooler lines. ground off part of front differential case to allow filter clearance. dropped front end of front drive shaft, and lifted motor slightly without unbolting l/side mount to allow filter removal and install. used short filter. i believe a long one will fit but have concerns about differential movement on bumps as there is little clearance between differential yoke/shaft and filter. have a new motor mount but have concerns about condition of differential mount bushings and movement. i believe there is a bypass in block at oil filter pad and am not sure if i need a bypass filter. vehicle has 441k miles and thinks it is bulletproof. would hate to prove it wrong! any input on what i did that wasn't necessary or could have done differently is appreciated as i am buying a 2002 model for my daughter and will probably be repeating this task on hers. thanks!
Old Mar 10, 2025 | 06:10 PM
Did your Blazer not also have an oil cooler connection to the radiator?
My 1999 has that which is nice for when I'm towing.
Old Mar 11, 2025 | 11:49 AM
47lougean's Avatar
yes. i kept all salvageable parts as i used to tow a boat and plan to again sometime. left side motor mount was shot and removing oil lines
facilitated its replacement. oil lines were rusted and i had "patched" them to hold me over. decided to try the deletion at this time. so far so good. will know more come warmer weather.
BlazeCat
May 4, 2021 07:27 PM
ruclean
Apr 25, 2018 01:52 PM
88BLAZER4X4
May 12, 2014 02:28 PM
Fullsizeon38s
Jan 26, 2013 09:50 AM
wyoboss
Oct 10, 2011 06:01 PM
