1st post. 03 Blazer. Plow and Tbar question
Old Nov 1, 2015 | 07:45 PM
Jdizzie's Avatar
Jdizzie is on a distinguished road
Default 1st post. 03 Blazer. Plow and Tbar question
Hey all.
I was plowing with a 98 blazer and a fisher homesteader 7'4' plow.
Well, at 178k I blew the motor and have decided to get a new truck and keep my old blazer as a parts hog.
I always noticed that I could get more range from the plow after I did a full turn on the torsion bars for the front of the truck.
i looked at the rough country 2.5" lift kit andit doesnt seem worth the money.
My new blazer is an 03.
Whats the best way to get lift?
Tbar crank?
RC kit?
other lift kit?
Thanks for the replies.
Regards, -J
Old Nov 1, 2015 | 08:48 PM
Torsion bars are adjustable to keep front chassis ride height within spec. Ride height is adjusted just before a wheel alignment. Even the slightest change in chassis ride height will substantially affect wheel alignment. When front chassis ride height is out of spec, you can expect excessive wear on most of the suspension parts, and some of the steering linkage parts. Installing a suspension lift will increase ride height, most likely out of spec. Adjusting the ride height back into spec defeats the purpose of the lift. Installing a plow will cause ride height to decrease, probably out of spec. It can be brought back within spec by adjusting the torsion bars, and then performing a wheel alignment. The ride height adjustment and wheel alignment should be performed with the vehicle loaded as close as possible to the way it will be driven. If you really want it to be accurate, sit in the drivers seat while the adjustments are made.
Old Nov 1, 2015 | 09:51 PM
Jdizzie's Avatar
This will be my 4th blazer, and honestly, none have really been able to hold an alignment. The trucks always seem to pull to the right for me. I think I'm just going to turn up the torsion bars again. The homesteader plow is pretty light weight compared to most. I'd just like to get some extra lift for the least amount of money. $500+ for RC 2.5" lift kit and steering adjustment link doesn't seem worth it. I'm sticking with the stock tires and rims.
Old Nov 1, 2015 | 09:52 PM
Jdizzie's Avatar
Also, I don't really understand what the ride height has to do with a wheel alignment.
Old Nov 1, 2015 | 11:10 PM
richphotos's Avatar
It was pretty well explained by Chuck.
That man does know his stuff, VERY well.
Old Nov 2, 2015 | 10:59 AM
Jdizzie's Avatar
Better question is : where can I find the spec?
apo02
Dec 13, 2012 03:58 AM
drummerdude
Dec 28, 2011 09:29 PM
ohsofly
Lifting Tech
Aug 23, 2011 09:06 PM
ohsofly
Lifting Tech
Aug 14, 2011 12:42 PM
Kamelot314
Jan 14, 2011 10:35 AM
