2002 Chevy blazer sputtering
Old Aug 22, 2022 | 04:59 PM
  #21
GeorgeLG's Avatar
There is value in knowing the fuel pressure while the truck is running, especially as it goes from running ok to running crappy but lets start with the basics. What's the pressure at key on, engine off and then what is it ten min later with the engine still off?
George
Old Aug 22, 2022 | 05:16 PM
  #22
Perry910's Avatar
Perry910 is on a distinguished road
George
Key on engine off: 38 PSI ( my brother said it was 20 the first time with key on engine off) after he looked at it I cranked it up then switched it off and it was 38
10 minutes key on, not running: 34
10 minutes after running, engine off : about 46 PSI
30 minutes after running engine off: 38 PSI
Edit: lost the little black piece that covers the shrader valve. Where I test it. Does that matter
Old Aug 22, 2022 | 05:39 PM
  #23
GeorgeLG's Avatar
your fuel pressure is too low. Next you need to test it at the output of the fuel filter to cut the problem in half (fuel tank vs plenum).
https://blazerforum.com/forum/2nd-ge...eakdown-88305/
George
Old Aug 22, 2022 | 06:08 PM
  #24
Perry910's Avatar
George
ok initial pressure was good and after 10 minutes it was good as well, according to the numbers on the post, so it’s inside the engine somewhere
Old Aug 22, 2022 | 06:12 PM
  #25
GeorgeLG's Avatar
38 psi at key on engine off is too low, the engine will not run properly.
George
Old Aug 22, 2022 | 06:17 PM
  #26
Perry910's Avatar
George
what do you think that could be? I was thinking about buying a fuel pressure regulator and seeing if that changes anything. The spider injectors have been replaced about 6 years ago
Old Aug 22, 2022 | 06:23 PM
  #27
Perry910's Avatar
Also when I was driving to the store and messing around with the OBD tester and this was showing while I was driving.
File Type: mov
Old Aug 22, 2022 | 06:34 PM
  #28
GeorgeLG's Avatar
You need to repeat the fuel pressure test at the fuel filter outlet to help narrow down the location of the failure.
Evap system failures are very common and almost never result in engine performance issues, your just destroying the ozone, or so we are told. You need to fix your fuel pressure problem first.
George
Old Oct 16, 2022 | 05:10 AM
  #29
Perry910's Avatar
I wanted to thank you for all the help brother. I finally got tired of messing with it and took it to a shop. They welded a exhaust on it to stop the exhaust leak where I cut the cat off and it runs brand new now!!!! He said where the leak was the O2 sensor was sucking up air and dumping fuel into the engine.
George
Old Oct 16, 2022 | 08:58 AM
  #30
GeorgeLG's Avatar
Glad your fixed up, thanks for reporting back.
George
mdakota59rt
Dec 10, 2021 03:07 PM
DebbieB
Jun 4, 2018 04:42 PM
bigbrody
Jan 29, 2017 09:00 AM
timothyjw50
Apr 23, 2013 03:48 PM
