4x4
Old Jan 4, 2015 | 10:59 PM
tadlockryan's Avatar
tadlockryan is on a distinguished road
Default 4x4
My 4x4 doesn't work, I bought it like that, what is the likely part/parts that are broke and need replaced?
Old Jan 5, 2015 | 10:30 AM
tenorsaxdude's Avatar
tenorsaxdude is on a distinguished road
Going to need a bit more info. Year, push button or manual, and any diagnostics you've done for it
Without knowing my first dart would be the vac system
Old Jan 6, 2015 | 11:07 AM
its a 99' 2 door push button 4x4
Old Jan 7, 2015 | 02:53 PM
jbrooks19's Avatar
jbrooks19 is on a distinguished road
Could be any of the following: Front Dif Vacuum actuator, button on the dash, TCCM or Encoder/Transfer Case Motor.. Do the lights come on the buttons? Do you here a click from the TCCM? Does the drive shaft off the transfer case spin freely when in 2wd and when you push 4hi or 4lo does the driveshaft stop being able to rotate by hand?
Give us some details on what it is doing, if anything at all.
P.S. The search function is your friend. 4x4 issues are a dime a dozen and often, with searching, your answers can be found.
Old Mar 15, 2015 | 05:25 PM
There's no lights, no clicks, nothing almost like it doesn't exsist lol. I'm going to replace my actuator first.
I haven't tried messing with the shaft yet, but if it locks when I press the 4x4 what does that mean?
Old Mar 16, 2015 | 08:12 AM
I wouldn't replace it yet.
If you don't have any lights on your push button start there. Check fuses and plugs (i.e. cleaning or tight fits)
Button module is a pop out module that can be checked easy, the TCCM is behind the kickpanel on the passenger side. Check those connections too
Old Mar 17, 2015 | 06:22 PM
Default 4x4 connections
I checked all of my connections, nothing looked weird or out of place, it all checked out to me.
Old Apr 5, 2015 | 02:34 PM
Old Skool Soldier's Avatar
Old Skool Soldier is on a distinguished road
Mine would only go to 4 lo and 2 hi. I just unbolted my battery and disconnected/reconnected the TCCM, waited an hour, re bolted, and everything works! I was going to start throwing parts at it
Old Apr 5, 2015 | 09:16 PM
richphotos's Avatar
easier thing to do, just an FYI for next time, pull the TCCM fuse from under the dash for a minute, put it back in. resets the tccm.
Old Apr 6, 2015 | 12:48 PM
I got it! It was my courtesy lights fuse that was bad, I replaced that and everything lit up and switched over perfectly!
Manteray
Oct 2, 2011 11:53 AM
razman
Feb 22, 2009 01:57 PM
sfesenko
Nov 30, 2008 08:55 PM
sdm1234
Jan 2, 2008 12:12 AM
tolleyc
Jul 29, 2007 05:57 PM
