4x4
Could be any of the following: Front Dif Vacuum actuator, button on the dash, TCCM or Encoder/Transfer Case Motor.. Do the lights come on the buttons? Do you here a click from the TCCM? Does the drive shaft off the transfer case spin freely when in 2wd and when you push 4hi or 4lo does the driveshaft stop being able to rotate by hand?
Give us some details on what it is doing, if anything at all.
P.S. The search function is your friend. 4x4 issues are a dime a dozen and often, with searching, your answers can be found.
There's no lights, no clicks, nothing almost like it doesn't exsist lol. I'm going to replace my actuator first.
I haven't tried messing with the shaft yet, but if it locks when I press the 4x4 what does that mean?
I wouldn't replace it yet.
If you don't have any lights on your push button start there. Check fuses and plugs (i.e. cleaning or tight fits)
Button module is a pop out module that can be checked easy, the TCCM is behind the kickpanel on the passenger side. Check those connections too
Mine would only go to 4 lo and 2 hi. I just unbolted my battery and disconnected/reconnected the TCCM, waited an hour, re bolted, and everything works! I was going to start throwing parts at it
easier thing to do, just an FYI for next time, pull the TCCM fuse from under the dash for a minute, put it back in. resets the tccm.
Manteray
Oct 2, 2011 11:53 AM
razman
Feb 22, 2009 01:57 PM
sfesenko
Nov 30, 2008 08:55 PM
sdm1234
Jan 2, 2008 12:12 AM
tolleyc
Jul 29, 2007 05:57 PM
