77 Blazer Antenna cable
Old Jan 12, 2017 | 09:03 AM
3100's Avatar
3100 is on a distinguished road
Default 77 Blazer Antenna cable
Hi knowers, i own a 77 Blazer K5 and i am seaching for the electrical cable for the antenna Motor. Where does it enter the cab an which color is the cable? Thx
Old Jan 12, 2017 | 09:29 AM
The antenna should be integrated into the windshield (center bottom should be a snap like connector) and would not have passed through the firewall into the engine compartment.
If it has been converted to a fender mount, you'll need to follow the current cable to see where they passed it through.
If it hasn't been converted and you want to move to a fender mount, you'll likely need to drill your own hole and procure a grommet to protect the wiring. Anywhere under the HVAC box should work, but make sure you check for obstructions on both the inside & outside before drilling.
Old Jan 12, 2017 | 09:36 AM
3100's Avatar
Thanks for the fast reply
TexasRider
May 30, 2013 09:10 AM
Squad-6
Apr 22, 2013 02:19 PM
wings4kites
Jun 16, 2011 06:42 PM
rastoma
Nov 12, 2009 05:16 PM
johng
Jan 16, 2008 06:08 PM
