97 beak pads swap to a 02 blazer ?
Old Nov 4, 2017 | 01:32 PM
bertaboys's Avatar
bertaboys is on a distinguished road
Exclamation 97 beak pads swap to a 02 blazer ?
can I take my 97 blazer front break pads and swap tem to my 02 that I'm buying ?? save me fro buying new pads again.
Old Nov 4, 2017 | 01:47 PM
So long as it's 2wd to 2wd or 4wd to 4wd, I would like to say yes. But pads are like $20, seems to me like it would just be easier to buy new ones and do half the work (instead of tearing one part to just put the pads in the other...)
Old Nov 6, 2017 | 07:49 PM
El_Beautor's Avatar
I'm almost certain that they are slightly different size/shape. The S-Series trucks switched to a slightly different caliper with 2 smaller pistons in '98. Check your '97. If it has a single piston on the caliper I believe that the pads will not fit on the newer '02. The rotor on the '97 and older is also slightly smaller vs the '98 and newer.
For the few dollars you might save, I think you'd be better off just putting new brake pads on your new truck.
Old Nov 7, 2017 | 08:38 PM
bertaboys's Avatar
thanks buddy just figured because I literally just did the breaks id ask but pads are cheap. so not a big deal
madmaxxed
Jun 8, 2015 01:08 PM
sweezo
Jul 23, 2011 03:42 PM
jonesjt
19
Feb 20, 2009 10:39 AM
KarenC
Feb 13, 2009 07:02 AM
jsmz
Sep 26, 2008 11:55 AM
