Adjusting 1-3 inch Torsion Keys
Old Mar 9, 2024 | 10:38 AM
BlazeOneDown's Avatar
BlazeOneDown is on a distinguished road
Default Adjusting 1-3 inch Torsion Keys
I purchased a 1995 Blazer Lt and he installed 2” shackles and 1-3 inch keys. Question is if I lower the torsion keys down can I avoid front end parts wearing out or should I source stock keys? Thanks for you help!
Old Mar 11, 2024 | 12:47 PM
El_Beautor's Avatar
You should be able to turn the keys down and lower the front to factory ride height. The best way would be to have a alignment shop do it because they'll know the proper suspension measurements to be within factory spec, and you're going to want a wheel alignment done after changing the front suspension dynamics.
If you want to do it yourself and to get close to factory, look for the CV axles to be near level. One full turn of the torsion key bolt equals approximately 1/4" ride height. Remember that you need to drive the truck around the block after adjusting the torsion keys so that the suspension has a chance to settle before you do any measurements.
Old Mar 11, 2024 | 09:52 PM
Thanks for the feedback! I’m need to replace the idler arm and pitman arm as well. I’ll get it all done and get it in for an alignment. Much appreciated.
Old Mar 12, 2024 | 12:21 PM
Here are the specs for for the suspension heights from my 1999 service manual.
You might find out like I did that my suspension components have sagged a bit over the years. I have new springs and torsion bars I'll be installing later in the year.
Old Mar 12, 2024 | 09:28 PM
i really appreciate it. I have replaced all suspension parts, leafs, front and rear shocks all new front end but pitman and idle arm. I’ll try and get it to spec and check for sag. Thanks again for the reply
02blazr
Lifting Tech
May 7, 2013 11:26 AM
schoolhouseneon
Lifting Tech
May 29, 2012 08:16 PM
1998LT
Lifting Tech
Sep 28, 2010 09:52 PM
bulldog3280
Lifting Tech
Feb 28, 2008 03:49 AM
sasquatchfound
Suspension Tech
22
Jul 19, 2007 12:28 AM
