Any put 31's on without totally messing up the ride comfort
Old Apr 4, 2023 | 03:29 PM
Alwright87's Avatar
Alwright87 is on a distinguished road
Default Any put 31's on without totally messing up the ride comfort
Got 31's on with only a lil hammer on the inside of front wheel well
Old Apr 10, 2023 | 08:14 PM
AJBert's Avatar
The factory did it for me, so I'll be no help. I had 33's on mine, now 32. The ride is fine, just less mpg's.
Old Apr 10, 2023 | 09:45 PM
I had a tire shop test fit both 30x9.5 and 31x10.5. The 31s fit except for them limiting how much I could turn the steering wheel before the tire touched the frame. I ended up going with the 30s.
Also, you can use a calculator to work out the difference in the actual speed and distance and what your speedometer and odometer read when you put on the larger tires. This will allow you to compute an accurate mpg. Note also that putting on larger tires will effectively reduce your axle ratio. This was a second reason I went with the 30s.
https://tiresize.com/speedometer-calibration/
https://tiresize.com/gear-ratio-calculator/
RedBlezer
Oct 4, 2018 09:24 AM
LucasMI
Jan 1, 2012 03:51 PM
Sisk
Apr 24, 2011 12:42 PM
99 blazer
Tires and Wheels
Nov 29, 2010 12:44 PM
jacobcnc
Feb 16, 2010 02:02 PM
