anyone instaled HID head lights on a blazer
#121
RE: anyone instaled HID head lights on a blazer
Did you get the wiring harness with it?
#122
i have them, pm me about them, i have 6000k and they are SO worth the 275 i payed, i will never go back to regular bulbs
just read my post i made a while abck here
https://blazerforum.com/m_120622/tm.htm
#123
Negative I didnt get the wiring harness with it, Im gonna try a new relay in my fuse box and if that doesnt work I'll have to order a harness..
Also does anyone have any idea why when i hook them up i have to turn on the highbeams for them to come on.. even though they are plugged into the lowbeams, cant seem to wrap my head around that one.
#124
Did you double check and make sure they're plugged in properly?
I think the highbeam plug will fit into the low beam plug... Are your high beams on when you turn your headlights on?
Did you do the quad beam mod?
#125
ok, idk if tis what you asking, the brights lights during the day are on but are dimmed, tese are drls, at night a snesor on you dash board turns on yor regular lights for you, you want to hook up the HIDS to LOWBEAMS(becasue thats what gets used the most) the switch is configured that when you turn on our highs, it turns off your low beams and vice versa, and since hids take about 6 seconds to come on, i highly recomend them as low beams, i hope that helped i could be completly off
#126
Yeah upon further review, every single time I hook the HID's up they blow the fuse in the Relay center within about half a second of turning the lights on. I ordered a wiring harness and Im hoping that will take care of the problem..
#127
Which kit did you get?
And the harness should ALWAYS be used with HID's... Factory electronics just aren't built for that initial start up charge.
Jake--Blazer
07-17-2013 02:04 AM
