Blazer steering geometry
Old Jan 20, 2014 | 12:52 PM
Diaita's Avatar
Originally Posted by LeWhite
Smiles and memories ...
Thanks for sharing! My dad used to tell me stories about when he used to work in a speed shop when he was young(about 50+ years ago). Great stories about how crazy that generation was, and would drag race anything.
Old Jan 22, 2014 | 02:40 PM
TZFBird's Avatar
TZFBird is on a distinguished road
Sorry the pic is so large. I'm wondering if these would change the angle that the tie rods are at. I suppose it would but I doubt it will be enough to really correct the issue. It would probably help to know what sort of forces are seen by the steering components. Otherwise something 'S' shaped would be required.
Old Jan 22, 2014 | 03:16 PM
Diaita's Avatar
Originally Posted by TZFBird
Sorry the pic is so large. I'm wondering if these would change the angle that the tie rods are at....
That TRE wouldn't change the geometry at all, it would only change where the link is located. In onder to change the geometry, you need to adjust where the end of the TREs or suspension links are mounted in relation to each other on the knuckle/frame/steering linkage.
Old Jan 22, 2014 | 10:39 PM
LeWhite's Avatar
Yeah that wont do a thing! I thought you meant TRE with a longer ball joint stud, which are used to correct bump steer.
Old Jan 25, 2014 | 12:46 PM
TZFBird's Avatar
I saw the thread about adding a stud and using heims. Instead of normal rod ends. Both sides can be changed out for around $80. Definitely a better deal than those offset rod ends.
Old Jan 25, 2014 | 03:21 PM
Diaita's Avatar
Heim joints wear out pretty fast on a street vehicle, and in a lot of areas illegal for as well.
ctyler
Aug 25, 2020 04:06 PM
litterbug
Oct 19, 2011 07:50 AM
Parilio
Sep 21, 2011 06:56 AM
caseroj
Oct 20, 2010 08:10 AM
rjenkins26
Lifting Tech
Apr 4, 2009 10:54 PM
