Busted mirror
Old Feb 11, 2014 | 11:55 AM
browndog77's Avatar
browndog77 is an unknown quantity at this point
Default Busted mirror
Hi all-
Yesterday while shoveling snow (almost a daily event in the northeast lately), I accidentally backed into the side mirror (passenger) on my '97 s10 and it snapped right off. The plastic triangle shaped base was hanging by the wires. I duct taped it immediately since I had an appointment, so I did not get a look at exactly what broke. Since it is currently about 10 degrees out and there is no relief in sight, weather-wise, I was hoping someone can give me a heads up as to what I'm gonna need when I do the repair. It broke so easily that I think it may be a glue joint, or maybe was already cracked. Is it a bracket or part of the trim itself that failed? If I have to undo it to find out it will be a double pain cause I will have to retape to run for a part if I need one.
Thanks in advance for any insight!
Old Feb 11, 2014 | 02:23 PM
rexmburns's Avatar
Super Moderator
They are a common item to break. Best to just replace the entire assembly. You only have to partially remove the interior door panel and then it's three nuts to remove the entire mirror assy. I have a few spares but not sure if I have any power mirrors. Post a pic of what style you have.
Old Feb 11, 2014 | 02:33 PM
247monster's Avatar
yep 8mm bolts if i remember correctly
Old Apr 6, 2014 | 10:19 AM
Brian5792's Avatar
Brian5792 is on a distinguished road
This may be too late to help but .... I had a similar problem on the driver's side on my '98 LT but, since I was not at home, I had to cut the wires. I had the entire black triangle-shaped piece - unbroken - but "separated" from the rest of the assembly. Seems this was not the first time it broke as there was lots of super glue. The back side of the black triangle originally contained 3 plastic "bolts" that are meant to fasten to the three nuts rexmburns spoke of. Since my bolts were a broken, glue-y mess, I chose to drill them out. I replaced them with metal bolts and nuts and said "who cars if I can see the bolt heads on the outside?" Just painted them black. I could only replace two of the bolts this way because the head of the third would have popped up in an inaccessible spot outside.
Old Apr 6, 2014 | 11:54 AM
dragoon1101's Avatar
dragoon1101 is on a distinguished road
or just run to the junk yard and get a replacement mirror i chose to update my old power mirrors to the newer style (power) just had some re-wiring to do now they work but when you hit the right button to adjust it it goes left and vice-versa but the up down is correct one of these days ill go into the adjustment buttons and switch those 2 wires ... maybe
Old Apr 6, 2014 | 01:09 PM
Steve-o's Avatar
Steve-o will become famous soon enough
rockauto
Old Apr 6, 2014 | 09:04 PM
Badco's Avatar
Badco is on a distinguished road
Just gonna leave this here, when you do the mirror swap, youll need an extension and a deep socket just to make your life easier!
Awesome
19
Nov 27, 2009 12:39 AM
CodyT
Feb 15, 2008 04:40 AM
Maldo15d
Dec 4, 2007 08:00 PM
philipswanson
May 24, 2007 12:13 PM
blair77
Mar 6, 2007 09:03 PM
