Can a jeep tow a blazer???
Old May 2, 2008 | 09:30 PM
Default RE: Can a jeep tow a blazer???
ORIGINAL: 99blaz
Technically your not supposed to tow a 4wd vehicle at all. Only on a trailer or flatbed but as long as both the tranny and transfer case are in neutral you should be fine.
As I said, if the transfer case is in neutral, the upper bearings may not be sufficiently lubricated. It isn't because only two wheels are turning, it is how the transfer case is turning. It is just easier to take a 10mm wrench, a roll of duct tape, and a bungie cord with you.
For short trips, you shouldn't have any issue if the transfer case is in neutral (transmission in neutral for good measure), but for any extended towing, either flatbed/trailer or disconnect the rear driveshaft.
Old May 3, 2008 | 12:40 AM
lennyblazer's Avatar
lennyblazer is on a distinguished road
If you are renting a dolly from Uhaul, just spend the extra $10 and get the flat bed car trailer. I will save you time and will be sure not to screw up your truck. As far as the jeep pulling it, it should be fine, its got a v8 and some decent axles. Just make sure its a class3 or higher hitch and check the tow ratings (from a quick search on edmunds, i found that a 1996 grand cherokee with the 4.0LI6 has a max of 5,000 pounds, which with the blazer and a trailer would be darn near that, so I would say you should be fine).
Old May 3, 2008 | 02:33 PM
99blaz's Avatar
99blaz is on a distinguished road
thanks swartlkk for expalaining it better lol. Wasn't entirely sure and I suck at explaining things.
Old May 3, 2008 | 03:43 PM
No problem! That's what we're all here for, to make sure that the OP gets the required information!!
shaun77
24
Dec 18, 2012 02:50 PM
mattjphoto
May 31, 2011 10:16 AM
blazerJim1701
Aug 24, 2010 12:09 AM
matthew.chapman1
Feb 12, 2010 02:00 PM
blazerJim1701
Suspension Tech
Jul 6, 2009 09:32 PM
