Charcoal evap canister hoses diagram
Old Dec 30, 2024 | 11:04 PM
  #31
Kona1611's Avatar
Kona1611 is on a distinguished road
Default 2002 zr2
I have tried a different drive cycle and caused .
my catalyst monitor to complete...which turned on my ck engine light and showed code P0420. I checked and found a couple of leaks in my exhaust system. I repaired them. The problem still exists. My evap monitor is still incomplete. Now where do check or look to find out the cause for this code?All help is appreciated. Thank You. Hv a happy New Year.
Old Mar 9, 2025 | 08:49 AM
  #32
Kona1611's Avatar
Default Two monitors incomplete, evap and catylist
I have replaced evap solinoid, and leaking fuel line replaced, also found a hole in exhuast and fixed that. Now two incomplete monitors, evap and catylist. No check engine light. Would like to clear evap first if possible. What drive cycle should I follow to do that? All help appreciated. Thanks. Hv a gr8 day.
Old Mar 13, 2025 | 10:11 PM
  #33
Kona1611's Avatar
Default 2002 ZR2.....two incomplete monitors
[img alt="Kona1611's Avatar"]data:image/svg+xml;utf8,<svg xmlns='http://www.w3.org/2000/svg' viewBox='0 0 50 50'><circle class='avatar-circle-default' fill='%237570c2' cx='25px' cy='25px' r='23px'></circle><text class='avatar-text-default' x='49%' y='53%' fill='white' text-anchor='middle' alignment-baseline='middle'>K</text></svg>[/img]
Kona1611
wetbar
16
Mar 14, 2021 10:13 PM
mike5511
Nov 8, 2018 07:48 AM
puckrocker
Mar 2, 2011 02:01 PM
2000Bansheeboy
Dec 30, 2010 06:52 AM
jphayes921
Apr 5, 2008 07:25 PM
