CV axle
Old Feb 13, 2019 | 04:50 PM
BritishColumbiafishing's Avatar
BritishColumbiafishing is on a distinguished road
Default CV axle
Put a 2.5 lift on a 2002 4 door blazer and destroyed my cv axles,I understand that changing the angle on the axle on an older vehicle can do that I also get not to crank up the tortionbars. So all the work was done right .I have replaced the cv axles and seems to be ok so far. The vehicle is used for wheeling and goes on alot of backcountry trails so is expected. So QUESTION BEING is anyone firmiliar with the differences in ZR2 oem cv axles I have herd that they are a 1/4 inch longer then mine on the LT model ? Will it make up that distance from mine being lifted? What are peoples thoughts
Old Feb 13, 2019 | 06:43 PM
cleburne red's Avatar
I don't think they'll work. I've always read that they were too long
Old Feb 13, 2019 | 08:54 PM
What was the failure mechanism for your CV axles? Did the boots come off allowing the joints to become contaminated? The original boots are pretty stiff and I have discovered that my inner boots were being pulled off. When I had one of CV axles out I replaced the inner boot with a new neoprene one that was much more flexible. I also took the opportunity to clean the joint and fill it with fresh grease.
Old Feb 13, 2019 | 09:41 PM
It pulled it right out of socket and destroyed it from running it home like that
Old Feb 13, 2019 | 09:48 PM
Yikes!!! I could see with a larger angle to it, there would be an extension of the axle itself. It would seem that the clip on the splined part of the axle must have lost tension and allowed it to come out.
Old Feb 14, 2019 | 12:16 AM
Yes so apparently the zr2 axle is roughly 1/4 inch longer, wondering if that would make up for the length since it is lifted
Old Feb 14, 2019 | 09:47 AM
El_Beautor's Avatar
I'm pretty sure that it's more than 1/4" longer than a standard s-series. The ZR2 has about a 2" wider stance than the standard s-series truck, and I believe that the cv axle is closer to 2" longer on the ZR2. I'll try and see if I can get measurements to post tomorrow to be sure.
Old Feb 14, 2019 | 02:06 PM
thanks brotha that would be awsome
Old Feb 15, 2019 | 06:08 PM
El_Beautor's Avatar
Had my brother measure for me as he has both a non-Z and a ZR2 in his shop at the moment. Measuring from the diff-face (excluding the shaft inside the diff) out to the hub face (excluding the shaft extending through the hub) the measurements are:
- ZR2 = 18.5" (+/- 1/4")
- Non-Z = 15.5" (+/- 1/4")
There's probably a parts catalog around somewhere that would give more exact measurements, but even these show that the ZR2 CV axles are a lot longer than the non-Z, even taking into different angles and such. They are not interchangeable.
SimpleManAustin
Jan 28, 2019 11:57 AM
matt9589
Aug 21, 2013 09:55 AM
dj00140
21
Apr 24, 2013 08:55 PM
tony991
17
May 6, 2010 01:05 PM
nonstop
22
Jun 7, 2009 07:16 PM
