Did I get shafted ?
I took my 96, 4.3, 4x4 to a local mechanic to replace a leaky intake gasket. When I went to pick the vehicle up it was knocking very loud. I left it on his lot overnight becouse I was afraid to drive it home. The next morning, i went to the lot to move it into the back of the lot just to get it out of his way. The engine totally locked up when I tried to start it. I actually drove this truck to the lot with no pings or knocks, just leaking water and antifreeze as fast as I could put it in. Should I snap this guys neck ? I feel like I just got screwed. I am out 500 dollars and have a total engine replacement on my hands !
I would appreciate any and all opinions, especially where to find an engine !
Buddy that is Brutal! What if anything did this so called mechanic say when you confronted him with this. By your statement I take it you already paid him for the gasket job. I personally would take it to small claims court. As for an engine try your local salvage yards. You can usually swing a good deal there. The 4.3 was in a lot of vehicles so to my overall knowledge you could drop one in from just about any source, I am sure more enlightened individuals than I will be able to clarify the validity of this statement. Best of luck my friend.
Leaking intake gasket? Leaking into where, the engine block, hence into the engine oil. Oil and water dont mix, especially when it comes to bearings. The fastest way to fry an engine is by using water instead of oil. Itll lock em up tighter than a drum. A loud knocking noise, sounds like rod knock. They make one hell of a racket when knocking. I have a 4.3L sitting in the garage with a bad #1 piston bearing. I paid the previous owen $50 for the truck, swapped in a rebuilt engine and my son drove the truck for 2 years, recently sold it for $1000 and now someone elses son is driving it.
jhood17
Jun 30, 2010 05:54 PM
jdpilot
Mar 28, 2006 10:52 PM
