disappointed in my blazer...
Old Sep 18, 2011 | 09:53 PM
hasek1616's Avatar
hasek1616 is on a distinguished road
Originally Posted by btmbass
Hasek, I'd recommend the A/T if this is a daily driver. I have had 30" BFGoodrich A/Ts on my stock height blazer since april and haven't had a problem onroad or offroad with them.
thanks for the recommendation, i might just go with those, but if i pick up this Superlift Part 3103-6 - Torsion Bar Adjuster Arms will i be able to safely go a bit bigger?
Originally Posted by zr2dan
bf at's pretty good tires i run the 31/10.50/15 but zr2 with a little lift but i was wondering if you were burried to your frame feilds can be pretty soft
nah there was basically no mud, it was a bit damp since it was at around 9 pm but that was it.
Last edited by swartlkk; Sep 20, 2011 at 04:47 PM. Reason: *Combining Consecutive Posts* - Please use the multi-quote feature to respond to quote multiple people in one post.
Old Sep 18, 2011 | 09:57 PM
btmbass's Avatar
btmbass is on a distinguished road
To fit 31" tires, which is the next size up, you'd need to put in a 2" body lift or a 2" shackle along with a torsion bar crank. You can crank your current torsion bars to achieve the lift without having to buy that part.
These stickies go into the details
https://blazerforum.com/forum/tech-a...n-i-fit-41671/
https://blazerforum.com/forum/liftin...it-list-16186/
Old Sep 19, 2011 | 02:19 PM
hasek1616's Avatar
anything i can do to fix my open differential thats relatively cheap?
Old Sep 19, 2011 | 02:34 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
go to a junk yard and find a blazer that has a g80 differential (fairly common in stock blazers) and swap that rear end with yours. cheap and fairly easy to do if you have the time. oh you will also need to make sure that the differential has the same gearing.
Old Sep 19, 2011 | 04:38 PM
TheRandom1's Avatar
How often have you been offroading before? I drove my 89 S15 Jimmy through a construction zone and almost made it with really bald tires. Driving style has a lot to do with how far you can go offroad. Not quite as much as the tires you are using, but nearly as much.
Old Sep 19, 2011 | 04:55 PM
Thogert's Avatar
I would recomend the G80 idea, I love mine. It's great for the damp and muddy stuff.
Old Sep 19, 2011 | 07:00 PM
hasek1616's Avatar
its not just driving style, i did just fine in the ranger
what would be the difference between a g80 differential and the one in my car, and how can i tell if its a g80 diff? and will it say the gear ratio in my manual? thanks everyone for all the help, i just cant let my blazer get beat by a ranger haha
Last edited by swartlkk; Sep 20, 2011 at 04:48 PM. Reason: *Combining Consecutive Posts* - Please use the multi-quote feature to respond to quote multiple people in one post.
Old Sep 19, 2011 | 07:11 PM
Red 96''s Avatar
The G80 is a limited slip differential. Your diff is most likely "open," meaning that power will be going to the wheel with the least amount of resistance. So, if you were off roading and got into a situation where one of the rear tires was off the ground, the tire that left the ground will spin. You can tell if you have the G80 by looking in the glove box. There should be a sticker with a list of RPO codes. If you see G80 anywhere on the list, then you have the limited slip.
Old Sep 19, 2011 | 07:28 PM
hasek1616's Avatar
ok so most blazers will have the g80? or is there a certain model that has it? and how much should i pay for one? how about one of these JEGS High Performance or is there a different model i should be looking at? and how exactly would i figure out which one is right?
Old Sep 19, 2011 | 08:03 PM
Red 96''s Avatar
No, the G80 was included in the ZR2's and was an available option for all other Blazers. Your best bet would be to try and find somebody parting out a ZR2 or find one at a junkyard and pull the axle, or just the carrier itself
