disappointed in my blazer...
Old Sep 20, 2011 | 06:40 PM
  #31
TheRandom1's Avatar
A loose dirt road is probably best, but yeah, wet grass would probably work too. Just make sure your 4 wheel shows engaged before doing it.
  #32
xgiovannix12's Avatar
you can always jack all 4 wheels up and see if the 4wd works
Old Sep 20, 2011 | 10:46 PM
  #33
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Originally Posted by hasek1616
so if i just pin it on say wet grass and if one of the front wheels spin then im good, but if neither of them do then my 4wd doesn't work? and btw, how do you like your flowmaster super 40? i've been looking at picking one up
i really like the 40 series. it gives a nice deep rumble all throughout the rpm range until about 4500 rpm. the high flow cat i later added didnt really change a whole lot. just gave it that kind of popping sound when you let off the gas (dont really know how to explain it) ill link a video of what it sounds like with the stock cat.
sorry video is kinda short and thats the sound at about 2000 rpm
97 blazer 40 series muffler - YouTube
Old Sep 20, 2011 | 11:30 PM
  #34
litterbug's Avatar
if you want to make sure its working i would put it in 4x4. then put it in reverse. and then stomp on it. make sure you are on grass or gravel. if it grabs then the front is spinning but if the back tires just spin then its not engaging. i had this problem a while ago. i went through a couple actuators and solenoid switches and such.
i would also put the truck in 4x4 and reach under, grab the front driveshaft and if it is locked then the transfer case is working it would just be your actuator. check the lines to make sure there are no kinks or cuts on the lines.
also if you are turning and you have the 4x4 on, it will be hard to turn while the wheel is cut all the way. almost like it is binding.
Old Sep 21, 2011 | 12:02 AM
  #35
if you turn the tires on bare cement you will hear one of the front tires slipping. But the best option would be to get on something slippery and try the reversing idea
Old Sep 21, 2011 | 02:03 AM
  #36
Thogert's Avatar
Originally Posted by 97cherryblazer
personally i guess i got lucky and i have the the Gt4 G80 in my 4dr blazer.
Me too! Driveline-twin powers activate!
Sorry, couldn't help it.
Old Sep 21, 2011 | 11:16 AM
  #37
91chevywt's Avatar
91chevywt is an unknown quantity at this point
Whenever I want to check on my Jimmy, I can put it in 4x4, then grab the driveshaft between the t-case and front diff. If it spins freely, it's not engaged. It may have a little play in it, but there should be a big difference between when it's in 2wd and 4wd.
To see if the front axle is locked, you can put it in 4x4 and try to drive a little on dry pavement. The steering wheel should be significantly more-heavy and the tires will skip on tight turns.
Old Sep 21, 2011 | 03:35 PM
  #38
hasek1616's Avatar
hasek1616 is on a distinguished road
Talking
im gonna go out and try the reverse test right now, i'll get back to you with the results, here's hoping it works
Old Sep 21, 2011 | 03:36 PM
  #39
hasek1616's Avatar
that sounds sweet, what offset did you get?
Old Sep 21, 2011 | 03:42 PM
  #40
hasek1616's Avatar
well i tried the reverse test and it spun in 2 and 4, so it looks like i get to tear into my 4wd system, thanks to everyone for all the help
