Door Hinge Replacement
Old Sep 3, 2020 | 10:45 PM
Originally Posted by Mods
bit of a dead thread but this is still something i would like to know - How are the hinges welded on to these trucks? Door and body side, Seam welded around the edges or spot welded, and is it possible to remove them at home.
I looked it up in my 99 Service Manual and according to the pictures and instructions, you remove the original hinges by breaking the welds with a chisel. Then you use the weld marks to create pilot holes for drilling out to 13mm that will be for the bolts that attach the replacement hinges.
If the parts are still available, I'm guessing they would come in a kit consisting of the hinge, the bolts, nuts and backing plate.
If you are interested, I could scan this for you and post it here.
Old Sep 3, 2020 | 11:42 PM
Mods's Avatar
would appreciate the manual if you could. and Dorman makes repalcement hinge sets.
Old Sep 4, 2020 | 02:01 AM
Here ya go!
Old Sep 4, 2020 | 12:42 PM
Mods's Avatar
Here ya go!
Thank you! would've never thought it was that simple, just need a bigger garage....
Old Sep 4, 2020 | 01:27 PM
You are very welcome. But I wouldn't be so fast to expect it to be simple until you have done it!
If I read it correctly, you might have to take the dash cover out for front hinge replacements which apparently is a pretty arduous task in itself.
Good Luck!!
Old Sep 4, 2020 | 01:50 PM
Mods's Avatar
Good Luck!!
probably has to do with getting the backing plates in, which i can do from underneath the hush panel iirc
HostileJava
Oct 18, 2013 07:11 AM
Jhowey
17
Apr 7, 2012 04:50 PM
docta J
Dec 7, 2007 11:33 PM
gserve
Nov 2, 2007 08:42 PM
guywm25
Apr 5, 2007 11:03 AM
