Engine temperature
Old May 9, 2009 | 08:51 PM
Flying3's Avatar
Flying3 is on a distinguished road
Default Engine temperature
I recently bought a 2002 Blazer that seems to have an issue with engine cooling. I had a 2000 Tahoe that ran at 190 consistently. But this Blazer runs up to 225-230 regularly in traffic, drops right down and sticks at 190 if I am moving. Is this normal or should I flush and fill the coolant and maybe replace the thermostat?
Old May 9, 2009 | 09:47 PM
1oldK5's Avatar
1oldK5 is on a distinguished road
If the thermostat was sticking closed it would most likely only get hot on the initial warm up and wouldn't overheat after the stat opened. Its a definite possibility that it could be having poor circulation issues or if it has a clutch fan on it the clutch might be bad on it, had the same problem on my truck. Went to a flex fan and it works great even in traffic now.
Old May 30, 2009 | 07:33 AM
hkellogg's Avatar
hkellogg is an unknown quantity at this point
sounds like a bad fan clutch, but can't hurt to change the thermostat too
Old May 31, 2009 | 09:21 PM
PaulO2288's Avatar
PaulO2288 is on a distinguished road
Where exactally is the thermostat located? Is it under the black metal hose comeing from the middle top of the motor going to the upper radiator hose?
Old May 31, 2009 | 09:26 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
yup, thats where it is on a 2nd gen atleast, idk about the 1st gens.
Old May 31, 2009 | 09:27 PM
PaulO2288's Avatar
Im looking to get my truck running a little bit cooler also. Ive done a 180 to my Jeep and it ran great, and same with my moms Suburban and everythings always ran a little bit cooler but when I did it to my Jeep my heat went after that, It sucked anyway but maybe a freak accident im not sure. The suburban never did that just ran cooler and better. Would a 180 thermostat be fine for my 99 4.3 and would it affect my heat at all?
Old May 31, 2009 | 09:31 PM
mikeinwi's Avatar
use the search function and see what you come up with i know this has been discussed a number of times.
Old May 31, 2009 | 09:37 PM
PaulO2288's Avatar
Oh alright sorry
Old May 31, 2009 | 09:49 PM
rriddle3's Avatar
Quick, simple answer - no. You run the risk of the engine staying in open loop operation and your gas mileage and performance will take a nose dive. Stay with the 195 degree thermostat.
If you have further questions, please start a new thread so we don't hijack this one.
Old May 31, 2009 | 10:12 PM
bandidolenny's Avatar
Sounds like a defective fan clutch. Also, check to make sure that your fan shroud is in place.
stormyd
Jan 30, 2015 07:35 AM
chevyblazerfan
Apr 30, 2010 02:09 AM
ve3nsv
Nov 11, 2009 10:00 PM
Ola Nordmann
Feb 1, 2006 06:56 PM
djestes
Dec 30, 2005 11:33 AM
