Finally done with all fixes!
Old Nov 2, 2013 | 02:41 PM
Bobcat13's Avatar
Bobcat13 is on a distinguished road
Default Finally done with all fixes!
This isn't really a question but about 3 months ago now I bought a 4 door '97 Blazer 4x4 with 241K miles and I am finally finished with all the things it needed done as it was a heap when I bought it. I've replaced the air filter, fuel filter, fuel pump, had the pan dropped on the tranny with a new filter, changed the oil, sway bar links, inner and outer tie rods on both sides, idler arm, front pads and rotors, rear shoes, plugs wires cap and rotor, ignition coil, new tensioner and idler pulley on the serp belt, new intake and valve cover gaskets, new battery, and to top it all off a set of brand new GY Wrangler Silent Armors. Original 4.3 and trans, hoping to run them up to 300K miles before I replace them. Now time to customize a little bit! Lol
Old Nov 2, 2013 | 03:39 PM
chris015's Avatar
sweet, hopefully when you say intake,u mean lower (they are a problem) and i HOPE you got a ac delco/delphi pump. 95% chance you will be doing it over if not.
Old Nov 3, 2013 | 08:45 PM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
If you're really a Blazer owner then you'll learn that *NOTHING* is ever permanently fixed.
Also, since you've got a '97 it's likely that at some point in the future you'll be replacing the ignition switch. That seems to have been a bad year for the ignition switches.
Old Nov 3, 2013 | 09:04 PM
richphotos's Avatar
Oh, you are never done... LOL
Old Nov 4, 2013 | 08:50 AM
Bobcat13's Avatar
Well done for now at least...lol
newguy
Jul 31, 2013 02:31 PM
IronDobe
May 21, 2013 06:42 PM
midnightbluS10
May 21, 2013 07:04 AM
JMorton
Apr 11, 2011 10:46 AM
blazerguy22
Jul 2, 2009 08:22 PM
